Roland RD 700 repair
I’m working with a Roland RD 700. I just got new key contacts, from Syntaur of course. I do know if they are installed wrong they will play at odd velocity. The contact strips’ pattern fit key bed PCB and only one way so I’m sure they are in right however, the keys play at the velocity and response as if they are backwards. Again due to the pattern of the strips they will only go in one way. Is there something else I could be missing or need to check? (I did clean the PCB was well to ensure it was clear of dirt and debris as well)
