One of the first times I powered it on, the screen displayed “panel not respond”, and it had a clock timer counting upwards at the bottom of the screen.
None of the keyboard button lights were on, and the keyboard didn’t work at all.
I powered it off, and since then, it has worked fine each time.
I have 30 days to send this back, as I bought it using paypal goods and services.
I’m worried I’ve spent a lot of money for a keyboard which might have an intermittent and potentially expensive fault.
Does anyone know what causes this error, and does anyone have an Rd-88 service manual?
I’ve bought a RD88 4 years ago. A month after, the problem “panel no respond” started. I send back the piano to the Roland’s factory - no problem appears for them. Same for another technician. I’m stuck with a piano that doesn’t work most of the time, with a white noise when it’s plugged on stage…
waigy, treat “Panel not respond” as a comms fault, not a dead panel. Power off, discharge, then reseat the panel-to-main FFC/FPC at both ends. Inspect for a lifted latch, pin 1 orientation, oxide on contacts, and cracked solder at the header. Clean with 99% isopropyl and a lint-free swab. With the cable seated, confirm 3.3 V at the panel header and ground continuity from panel board to main chassis. If 3.3 V sags, trace the LDO and its 100 nF decoupling, not the whole rail.
lolap, scope the scan strobe and data/clock lines at the panel connector during boot. No activity means the main CPU is not polling, so check reset and clock at the panel interface. Activity but no key response points to a shorted tactile switch or leaky matrix diode holding a scan line low. Do not recap blindly; use ESR and DC ripple at the 3.3 V regulator.
What DC voltage do you measure on the panel header’s 3.3 V pin with the FFC connected and the unit in error state?
That’s the kind of info I’ve been looking for, and I have even contacted roland technical people before.
When I first asked about this fault, I had just bought the keyboard and had maybe 30 days to send it back for a refund, so I was powering it on almost every hour.
It was regularly having the “panel not respond” error, and eventually I got a large partial refund from the seller, who agreed to do that rather than take it back for a full refund.
Since then, I hardly ever use the keyboard, maybe once a week max, and the error has never happened again.
I will keep a note of your answer in case the error starts reappearing or happens more often, and I should be able to do what you suggested, as I have decent multimeters and a soldering iron etc.
