Sounds like your S-50 is having some other issues that you need to get sorted out first. Have you verified the power supply is outputting the correct voltages? Sounds like you might have a main board or power supply problem if your screen is only briefly turning on.
Thanks for the reply! Yes, I agree there are probably multiple issues at work. The display issue wasnt preventing booting, according to the person I bought it from…
I was hoping to just make sure that
I have the Gotek installed properly. I am breaking out the voltmeter to check the power supply today. Found the service manual online
Also, do you know if the CPU LED on the main board should be lit solid all the time?
Unfortunately I’m not particularly familiar with the S-50 so I’m not sure if that LED should stay lit, maybe someone else can chime in on that.
I have installed Goteks in various synths and samplers and some are more finicky than others. Does your Gotek have HXC or Flashfloppy installed?
Main things to be sure is the ribbon cable to the Gotek is connected properly; the red stripe should go to pin 1. If the Gotek is powering on then you must have the power cable on there correctly. For Roland synths you usually just need a jumper on S0 on the Gotek and no further configuration is needed.
Does the green LED on the Gotek light up at all? That light turns on when the synth is reading data from the Gotek. So if the synth is trying to boot that light should turn on.
Yes, the Gotek has Flashfloppy installed. The ribbon cable is installed correctly, I have triple checked the orientation and pins! Everything I can find online says the same, that normally a jumper on S0 is all you need, but not this time apparently!
The LEDs on the front panel light up normally, and as I mentioned, when I connect the composite video out to a monitor, the initial splash screen displays but gets no further.
Well. I think I’ve figured out the problem! The seller neglected to mention his amateur foray into soldering! It wasn’t obvious until I started disassembly by removing the main board and flipped it over to examine the underside. HOLY FRIGGIN MOLY!
