Hi, anyone have any experience with a Roland SBX-10 sync box?
I’m having trouble removing the main PCB from the upper face plate. The bottom of the case comes off fine but the are some tabs on the casing at the jack end of the board that are revealed when the jack board is taken off. When the board is pulled up the pot shafts in the middle of the board gets stuck on the face plate and don’t seem to want to be pushed back in far enough to allow the board to pop out? Any ideas as I don’t want to flex the board too much and crack it.
Sorry to necro the thread. Could you take a picture of the part (SKCMAE-13129731) on one of the two buttons on the machine? I need to locate a replacement.
