[CASIO] [CT-605] – [Seeking Replacement Tempo Fader]
Hey y’all,
Seeking a slide potentiometer with the following specs, as used on the Casio CT-605 and the Korg DW-6000:
Resistance: 1MOhm
Physical length: 45mm
Travel distance: 30mm
Taper: Reverse Audio (C)
Gang: Single
I have reached out to a few different places (including Syntaur) and unfortunately no dice, beyond buying a whole PCB from the Korg model to desolder the slide pot from. Does anyone have a suitable replacement part? Thank you!
• Model & revision/OS:
• Photos / audio clips:
