Service Manual for Studiologic SL88 Studio
Is there a service manual and or schematic available for the Studiologic SL88 Studio? Thanks!
Unfortunately they will only give them to authorized service centers. I will try their distributor. Thanks!
The distributor says they can’t provide a service manual
Hi, What is the problem with the unit?
None of the keys transmit note data either over MIDI or USB using either the included power adapter, The display lights up and the sticks are transmitting data over either MIDI or USB. This unit has never been moved except for when after having it for a year 2 key notes stopped working so I had to bring it in to get repaired and that worked for about a year than several notes stopped working and then none work like I mentioned. I have a friend who has decades of experience with electronics who is looking at it and says a service manual and or schematic would be helpful as he says nothing is marked or labeled . Thanks !
A picture or pictures of the inside of the unit showing all of the connections would be highly useful! Thanks
suddenly 8 keys in raw stopped working in my SL88 I Tried Changing FFC still same issue I think problem is with board or some component(Diode) got damaged did you find any solution I learned to disassemble each part including Hammers and keys PCB all and also Assembled it same as it was
