Hey all,
I just picked up a JD 800 but it came from the UK, I’m in Canada, obviously different power requirements. Thankfully the JD 800 seems to have a power supply that can be easily switched to different voltages by moving a single wire over.
Now I have no issue taking things apart and soldering a clearly broken connection if I have to, but I just don’t know anything about power delivery and the all the technical bits. So I figured before I go destroying my new toy I should ask here.
Is there anything else I would need to do here to properly convert this JD 800 to run at 120v instead of 240v ? Comparing my 240v unit to the photo here on Syntaur in the JD 800 parts section of a 120v setup, everything appears to be wired up exactly the same with the exception of the black ac wire (from what I can tell). On the small “primary board” the wires leading to the power switch and ac plug are not black and white on my unit, they are all brown but look to be wired up the same.
Power supply assembly, Roland - Syntaur!
My unit
Any help is greatly appreciated ![]()
thanks guys !
