Trying Arp/Pad w. Yamaha MODX7+
Hi. I am a newbie on Yamaha MODX7+.
I am trying to create Arp and Pad sound from Save Your Tears with MODX7+.
Perplexity suggested me to follow these instructions to create the sound. But I want to ask experts here if this is OK or not. I don’t have the synth yet but I will have it ready from the $10/hr practice room soon. I want to be prepared before the practice session.
Please help!
Basic Setup for Arp
Initialize a Performance
  • Start with an initialized FM-X performance
  • Select Part 1 and set it as an FM-X type
Oscillator Configuration
Operator Settings
  • Set Operator 1 as a square wave carrier
  • Set Operator 2 as a sine wave modulator
  • Set Operator 3 with a saw wave for additional harmonics
  • Set the ratio between operators to create harmonic content similar to the hyper/square combination
Envelope Settings
  • Set Amplitude Envelope:
  • Attack: 0ms
  • Decay: 430ms
  • Sustain: 0
  • Release: 100ms
Filter Configuration
  • Enable the filter section
  • Select 24dB/oct Low Pass filter
  • Set cutoff around 2kHz
  • Set filter envelope to match the amplitude envelope
  • Add slight resonance (10-15%)
Modulation
LFO Settings
  • Set LFO 1 to sine wave
  • Rate: sync to tempo
  • Depth: moderate (40-50%)
  • Route to filter cutoff for movement
Effects
  • Add Reverb:
  • Time: 1.5s
  • Mix: 25%
  • Add Delay:
  • Time: synced to tempo (1/8)
  • Feedback: 20%
  • Mix: 15%
Arpeggiator Settings
  • Turn on the arpeggiator
  • Mode: Up
  • Range: 2 octaves
  • Gate Time: 75%
  • Velocity: 100
  • Swing: 10-15% for groove
Performance Controls
  • Assign Super Knob:
  • Filter cutoff (0-50%)
  • Reverb mix (0-30%)
  • Set Motion Sequence:
  • Lane 1: Filter cutoff modulation
  • Lane 2: Amplitude modulation
The key to achieving this sound is in the precise timing of the envelope and the interaction between the filter modulation and the arpeggiator[9]. Experiment with the operator ratios and modulation depths to find the sweet spot for your specific needs[4][8].
Citations:
[1] https://pplx-res.cloudinary.com/image/upload/v1733064060/user_uploads/njbhccpbg/image.jpg
[2] Syntaur newbie can only post two links
Initial Setup for Pad
  1. Start with a new initialized Performance
  2. Press [EDIT] to enter the detailed editing mode
  3. Select Part 1 for editing
Basic Settings
  • Select AWM2 as the main engine
  • Set Polyphony to 12 voices for a lush sound[7]
  • Use two operators in parallel configuration
Oscillator 1
  • Select a basic sine/saw waveform
  • Set detune to a slight positive value
  • Enable 12-voice unison
Oscillator 2
  • Select a similar waveform but slightly different character
  • Set detune to a slight negative value
Envelope Settings
Amplitude Envelope
  • Attack: 350ms
  • Hold: 0ms
  • Decay: 640ms
  • Sustain: 70%
  • Release: 500ms[2]
LFO Configuration
  • Set LFO 3 to modulate the pitch/detune of both oscillators
  • Rate: Set to a slow value (around 0.5 Hz)
  • Depth: Subtle amount (10-15%)
  • Waveform: Sine or Triangle
Effects
Reverb
  • Type: Large Hall or R3 Hall
  • Time: 2.5-3.0 seconds
  • Pre-delay: 20ms
  • Mix: 40%[2]
Final Adjustments
  1. Use the Super Knob to control:
  • Reverb depth
  • Filter cutoff
  • LFO depth[9]
  1. Fine-tune using:
  • Part EQ to shape the overall tone
  • Filter resonance for additional character
  • Motion sequencer for subtle movement[7]
The MODX7+ has powerful Motion Control synthesis that can add extra dimension to the pad sound. Consider using the Envelope Follower to create subtle dynamic variations and the Super Knob for real-time control of multiple parameters simultaneously[9].
For additional expressiveness, connect an FC7 foot controller to control the Super Knob while keeping both hands free for playing[11].
Citations:
[1] https://pplx-res.cloudinary.com/image/upload/v1733063795/user_uploads/legiybhap/image.jpg
