Anyone have a clue were I can get a Yamaha DX21 display replacement? other then Ebay, I bought a few and I get on Forums but nobody would give me an correct answer on how to modify them to work correctly.
Just diy it…
Here are some upgrades/ replacements:
" I installed an OLED display in my DX21 to increase readability at night. It was surprisingly easy, after soldering a pin header to the display it was plug and play.
Display I used: EA W162-X3LW"
~reddit
If it’s the same display as a DX7, you can get an lcd on ali express for like two dollars.
I bought off of Ali express, it does not work or I don’t know how to wire it
From memory, the oem display has 14 pins and pins 1-14 are identical to the replacement. I soldered a link between pin 1 and 16 on the new display, and another link between pin 2 and 15, to power the LED backlight. My DX7 previously had a backlit LCD installed so I also had to remove the high voltage converter.
