Yamaha Dx7 Mk1 (Some sound problems)
Hello, I have been following this forum about keyboards for a long time. This time I have to ask about a problem I am having.
I have a Yamaha Dx7 Mk1, when playing a chord/note with an “infinite” sound, for example a pad, and holding it for several seconds suddenly the sound cuts off. This error happens randomly, sometimes it cuts off after a few seconds, other times the error never happens, and other times it takes around 20. …30 seconds or more.
Perhaps this problem is something common that happens in these models of keyboards that are already quite old. To complete the information on mine, I leave you these details.
This Dx7 has never had a repair from any technician, the battery has not even been changed. Right now the battery indicates 2.8 volts
It does not have any modifications or RAM memory additions. It is just like the original.
I have a sound card that Yamaha sells, it reads the sounds perfectly, and actually makes the same error as with the internal sounds. When playing a prolonged chord at some point it cuts off and stops playing, then if you play the chord again This rings again until the fault occurs again.
The Volume control works, but the “Data Entry” control apparently is not working.
The rest of the buttons and functions have no problems.
Please, if someone suggests measuring any component, I need you to explain it in detail so as not to make mistakes, I am not a specialist technician but I understand electronics, and I have a Polymeter to measure.
Maybe someone has had this problem before and knows exactly which component is failing?
I have read somewhere that they recommend changing all the capacitors, but I don’t know if that maintenance has anything to do with my problem.
Thank you very much in advance, if I need to send a video to improve the compression, let me know.
Problem Solved
If you had this problem with this keyboard I must inform you that you found the solution.
It turns out that the volume and data entry potentiometers break over time, no matter how much or how little you use them, they end up breaking and that generates quite anomalous behavior in the Dx7, so much so that in my case the “data entry” potentiometer broke, randomly generating volume cuts in the mono output, you simply have to change the potentiometer, or buy one on eBay or you can also buy a generic one and adapt it, which is very easy, I opted for the second option and I have managed to solve the problem, it is simply that
The big problem is identifying it since it does not have a direct or logical connection with the volume deductions, I hope you have luck.
