Anyone know what might cause the right channel to stop working? I replaced the volume slider with a new one. Should I start by testing the headphone jack and work backwards?
that sounds like a good idea. in the DX7 MK1 the audio channels are basically the same on all outputs. so if the right channel does work on the headphones, you know what to look for.
Thank you for the reply. I should have been more clear about the problem. This is a synth I bought as-is, which needed various repairs. I haven’t tried the audio out jacks yet, just the headphone jack. (I don’t have an amp, so if someone can suggest a way to test the output jacks, I’d appreciate it.) As for the headphone jack, here’s what’s happening: with the plug inserted all the way, only the left channel works. If you pull the plug out about halfway, both channels will work.
I desoldered the jack, sprayed it with Deoxit, and tested the three pins for continuity, and it appears fine. My plan is to replace it anyway and see if that fixes it. If it doesn’t, what’s the next thing to look for?
Thank you.
from what you tell me there could be a problem with the headphone amp or something on the soundboard, it would really be a good idea to test those outputs, because the DX7II has stereo outputs. I have a schematic here for a DX7 MK1 but it will be different for your synth.
for testing purpose you could use a jack to Cinch/RCA and try it on a hifi-set
Just updating the missing right channel status…
I’ve tried both replacing just the headphone jack and the entire HP/BC board with parts from Syntaur, but the problem persists. This tells me that the missing channel problem is elsewhere. I have a working DX7II that I used to compare the A and B output on both synths with, and they seem to match.
I’m at a loss at this point. I don’t know enough to know where to look next for the problem. It could be a setting that I don’t know about, I suppose, but I’ve been through all of them several times.
Any help is appreciated.
