Hi there, my Yamaha DGX620 keys make a loud clunk sound. All keys are affected.
When you release the held down keys and they return to the resting top of their travel they go thump! If you know what I mean. The thump happens when you let go of the key when the key returns to the top of its action.
Very loud now and at the annoy the neighbours stage.
Any advice thank you? Is there any products on your product page I should consider thanks?
There are two foam strips at the rear of the keyboard - one dampens the key as the weight hits the top of the frame the other softens the return to rest position.
I suggest replace both foam strips - Yamaha service agent can supply them
FYI, I have the same problem with my SY77. Really loud My EX5 is a little loud but not enough to be annoying. Probably just a common maintenance issue.
