hi guys, I have a p125 and suddenly a few of the keys stopped working. This is all the keys from the second last g to the last C. I played around with this ribbon attached and it seemed to work I can’t seem to work out the right model for this piece. Please let me know if you suspect it to be another issue!
Pianoman225, that range points to one matrix line, not six dead contacts. On the P-125 the upper key contact board feeds the main board through a fine-pitch FFC ribbon. G7 through C8 sharing a scan line means an open pin, cracked flex trace, or cold joint at the connector. Do not keep flexing that ribbon; the carbon traces crack at the fold.
Reseat the FFC after inspecting the latch and contacts. Clean pads with 99% IPA and a lint-free swab, not aggressive contact cleaner. Under magnification check the carbon contact pads and the flex traces near the fold. Set your meter to continuity and probe each ribbon pad at the keybed against its corresponding pad on the main PCB. Flex the ribbon gently near the connector while watching the reading. Any intermittent drop means replace the FFC or reflow the connector pins.
Which ribbon pin loses continuity when you gently flex it at the connector?
Thanks for that I’ll give this a test. Which is the correct part to replace that ribbon should I to replace it?
