Yamaha p125 touch sensitivity problem
I have Yamaha p125 and the D below middle c suddenly only produces sound at maximum volume. Any suggestions? Could this be humidity related, as rain has been torrential lately and humidity is in the 90% range
Assuming there has been no events lately, like a soda spill (most common keybed killer) . Probably a contact strip that needs cleaning or replacing. Likely an inexpensive easy repair.
No events. Thanks for the info. Now I’ll get to learn how to use it.
The contact strip prob has dust or dirt interfering with the function of the D key. You will need to take they board completly apart (every screw on the bottom), then take the cable support (3 screws) off, detach the ribbon cable from the main board (carefully pulling it). Then there are 8 screws visible under the hammers that need to be taken ont.
this will relase the keyboard from the botttom of the case. Once this is accomplished, the keys need to be taken off (unscrewed) where the D key is and one group of keys below and above the bad key.(These keys are groups of octaves.) At this point you will need to pull off the rubber contact strip, inspect and clean it with compressed air. DO NOT use any liquid or spray cleaner which will only make the problem worse…I guess you’ve figured out that this is not a simple fix…and maybe you should call
Yamaha Service to find a qualified technician in your area…just sayin…
Thanks for the response and the blow by blow how to info. I suspect your diagnosis is dead on and am now debating whether to attempt repair or take the 200 mile five hour round trip twice to drop it off at the nearest yamaha service and then pick it up again.
Is the keyboard still under the 3 year warranty?
Yes. It is the 400 miles/20 hours of travel to get it to a Yamaha service center and back that is the problem.
Did you get my message ?
Sorry, I just now saw it. If your offer still stands I would welcome the assistance. Would also like to pick your brain about other P-125 problems ( I have two, both have problems) and wonder if I should get parts like a replacement contact strip and key contact board prior to opening instrument up in case the problem is more involved than just dirt/debris as I would prefer to only do this once. Thanks.
What is the problem with the 2nd P-125? Maybe we can make one good out of the two to start with ?
Hello! I have the same problem.
I gave the key to Yamaha service and they told me that I spit water on it, even the fact the the problem appeared the first two months.
Truth is that they fixed it, but then again, after two months, they problem re-appeared.
So I guess that the problem is not water but a functional problem existing in certain series. If anyone knows anything about it , please let me know.
