Yamaha PF 85 Digital Piano
There is wear on these tabs that are covered with plastic, presumably from hammer striking here. Also, I noticed at the base of the tab there is solid plastic that goes across, but for the most worn tabs, this is even worn down all the way to the surface.
Was this originally solid all the way across or are the gaps intentional?
Is this wear irreparable?
