Hi, I just moved and my Yamaha Arius YDP-184 is having a little issue. the pedal wire got crushed so the prongs are broken. Am I able just to replace the cable for the pedals?
I found this part and wanted to be sure it was the right part:
Also, will it come with instructions for the repair? And is it a complicated process or not really?
Yes, that is the cable you need. It simply plugs in on each end, so there’s not really much to installing it. The same cable works for a number of different keyboards, so we don’t have specific instructions for any disassembly that might be needed, but I think it would be very simple.
