Hi.
Are the rubber key sensors for the YDP163 the same as for YDP162?
I see parts for the YDP163 aren’t listed here.
thanks
you mean the key contact circuit boards under the keys where the rubber contacts are?
They are NOT the same … different keyboard used in these two models - YDP-162 has the key scanner on the main DM board (parallel data sent via flat ribbon cable) whereas the YDP-163 has the key scanner on the key contact board ( serial data sent to DM board)
YDP-162:
230 V851480R CIRCUIT BOARD GHD EBUS L GHD_EBUSシート13
235 V852140R CIRCUIT BOARD GHD M G H D シートM 08
240 V852150R CIRCUIT BOARD GHD H G H D シートH 08
YDP-163:
230 WV760400 CIRCUIT BOARD MK-L M K - L シート
235 WV760500 CIRCUIT BOARD MK-M M K - M シート
240 WV760600 CIRCUIT BOARD MK-H M K - H シート
Hi.
Thanks for your reply. No sorry I meant the actual rubber contact strips…
