Welcome! To get fast, accurate help, please follow this when you post in Synth Repair.
1) Title (be specific)
Use: [Brand] [Model] – [Main symptom]
Good: Roland Juno-106 – No output on right channel after recap
Avoid: Help!! or Broken synth
2) Required tags
Add one Brand and one Model tag (Fault is optional but helpful).
Brand:
korg,roland,yamaha,moog, etc… (choose one) -
Model:
m1, juno-106, dx7, memorymoog -
Fault (optional):
no-power,stuck-key,distorted-audio,midi-issues,tuning-drift,keybed-contacts,noisy-pot,random-notes,battery,psu,recap- For a list of all current fault tags arranged by category you may check this post here.
If your model isn’t listed:
Use models-<brand>-tbd (e.g., models-korg-tbd) and reply in the pinned “Request a new model tag” thread with your exact model name + a link to your topic. We’ll add the tag and retag your post.
3) What to include
Model & revision/OS: (e.g., “DX7 MkI, firmware 1.8”)
Symptoms: What exactly happens? When did it start? Does it change with warm-up?
Work done so far: Parts replaced. What changed the symptom?
Photos / audio: Clear board photos, close-ups, short audio of the issue.
Extras (if available): Manual/schematic link, error codes, power region, MIDI/audio chain.
Safety: If you’re not comfortable around mains voltages, don’t probe the primary side of PSUs—ask first.
4) During troubleshooting
Post new replies with photos (don’t just edit the first post).
If your issue is for multiple different brand/models, start a new topic.
5) After you’re fixed
Mark the solution: Click the ✓ “Solution” on the reply that solved it (topic owners and staff can mark solutions).
Post a quick fix summary and part numbers if relevant (this helps the next person).
If a specific Syntaur part solved it, feel free to link it for others.
Thanks for helping make this a great repair resource!
